Having a conservatory built early in the new year and will be wiring it up myself. As a plumber can understand and carry out basic wiring but would appreciate advice on what I plan.
Where the conservatory will be located is next to a patio window. I have a SWA 2.5 cable from my garage coming up to a security light.
I plan to shorten this down and use this supply for 3 S/O 2 wall lights and a ceiling fan.
My thoughts on how to do this is to fit a 2 way consumer unit one for the S/O and the other for the rest.
I will wire in twin and earth although I do prefer singles to avoid joints but the wall will be plastered. Have read previous posts regarding using steel capping for the cable so am up to speed on that one.
Also read advice on depth of steel boxes and will be using 25mm for all of them and check first with the plasterer.
I'm unsure on how I will proceed with fitting the consumer unit and leaving the SWA coming out of the wall ready to connect after the plasterer will have finished and also with the T&E cables above the unit.
Do you just leave them clipped and sticking out and the same for the SWA.
Doing it like this would leave them showing afterwards and look a bit unsightly so I'm sure you guys must have a better way.
Incidentally I will be supplying directly from a 2 way consumer unit already installed in the garage supplying a ring main in there and the garage lighting.
Any advice or suggestions please.
wemyss
wemyss
