planning permission needed for horses in my field ?
  • Thread starter Thread starter apg
  • Start date Start date
Why not call the planning dept and ask them? They are usually helpful with such questions.
what is the current classification of the land? Be careful you don't wipe thousands of the value of your land by downgrading it from residential to equestrian
It might be a change of use scenario, rather than planning. If you charge others, then it might get classified as a change of business
The horses could come and graze on my grass in the back garden and it would not need permission. Same thing.
Equestrian land can be quite tricky.
Off the top of my head if it is just a field purely used for grazing then it should be an agricultural use. I believe if feed is brought for the horses and/or equestrian equipment is put on the land (jumps, shelters etc.) then it becomes equestrian land and a change of use is required, it therefore usually requires an application as horses don't tend to just eat grass.
Are there horse police now?
Who the heck is gonna notice or care if horses are grazing in your field, that's where we would expect to see horses - in a field.
Hay. Don't spur the neigh sayers.
Again if the land is Agricultural you will have to reclassify the Land as Equestrian.
You will also probably be required to erect some sort of Shelter on the land to protect the horses during inclement weather, plus the field would need to be checked if its too muddy or wet, the Horses could end up with "Hoof Rot".
