    Dismiss Notice
Planning refused one house but advised for 2.
Discussion in 'Building Regulations and Planning Permission' started by Dale Johnson, 25 Apr 2019.
  1. Dale Johnson
    Dale Johnson
    25 Apr 2019
    3
    Thanks Received:
    Country:
    Hello I am just after abit of advice/knowledge about a planning application I put in.
    It was for a single dwelling on the side of my house on a large garden plot. I put in for a single dwelling and was told to withdraw the application and put in for a pair of semi’s.
    There are not any single dwellings on my estate but I can’t get my head round them wanting two instead of the proposed one. Has anyone come across this before???
  2. Sponsored Links
  3. Dale Johnson
    Dale Johnson
    25 Apr 2019
    3
    Thanks Received:
    Country:
    The plot is roughly 30m in length by 19 metres wide. The proposed house was 9.5m by 8.5m. Planning even made me downsize at first and change the orientation of the house to face the turning head. Re-submitted plans and then they come back saying they have spoken to a senior officer and one house will not be accepted but I should go for a pair of semi’s. She said it is not in a similar pattern to our estate because there are no other single dwellings. I even asked if we could make it look like there was two houses but would be one. She flatly refused and sent a block drawing of where the semi’s should be.
  4. Dale Johnson
    Dale Johnson
    25 Apr 2019
    3
    Thanks Received:
    Country:
    Also there is a trunk water main running through the plot which has a 3m easement either side of 300mm pipe. So restricting some of the proposed development space.
  5. Mottie
    Mottie
    27 Feb 2017
    12,199
    Thanks Received:
    1,503
    Essexshire
    Country:
    Build two, sell one if that’s all you want.
  6. Mottie
    Mottie
    27 Feb 2017
    12,199
    Thanks Received:
    1,503
    Essexshire
    Country:
    I had the reverse - wanted to build two one-bed flats but was refused as local policy was against one bed dwellings. Was told to apply for a 3 bed house and permission was granted.
  7. Sponsored Links
  8. ^woody^
    ^woody^
    3 Sep 2006
    31,531
    Thanks Received:
    4,222
    West Mids
    Country:
    There had been a housing shortage for many years. Planners typically want best use of available land, but "being told" to withdraw and apply for two houses is a bit odd on that alone.
  9. bernardgreen
    bernardgreen
    3 Nov 2006
    24,291
    Thanks Received:
    2,373
    Bedfordshire
    Country:
    In some areas the councils are under pressure from central government burocrats to create large numbers of new homes, quantity not quality . This pressure creates local planning policies that will put as many houses as possible on land that is put up for development.
  10. Don't want to start a discussion on so called 'affordable' housing, but that might be the planners reason i.e.to encourage lower cost or starter homes which are unlikely to be larger detached dwellings.
    ps :cautious: what constitutes affordable housing is an ongoing debate in our local paper whenever any new housing development is proposed.
    • Thanks Thanks x 1
  11. John D v2.0
    John D v2.0
    26 Aug 2016
    6,315
    Thanks Received:
    876
    Country:
    Certainly in London they have a formula for density of new developments based on distance to amenities and public transport connectedness. I think it's so they can get as many people as possible in the best locations, rather than one multimillionaire taking the housing for 20 normal people in a good location.
    However it isn't retrospective so you get an odd mix of 30s low density urban sprawl with redevelopments/infill being either small terraced houses or 5 storey blocks of flats.
    However with house prices and availability being such a chronic problem i think it's positive to provide some housing, and the local plan is about the only way the local authorities can enforce it.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
