Plaster curves outwards near the floor...
16 Oct 2011
Hampshire
We had a plasterer come in and plaster our Victorian terrace house. Most of the work is fine, but when you get towards the floor where the skirting board should go, the plaster finish it curves outwards.
I now have to chisel off the work he has done to fit the skirting board. Is this normal.
Also the work he has done on skimming the walls, is not flat, it has many subtle and not so subtle waves in it, even where I have chipped off the plaster near the floor, there a large gaps behind the skirting board, nearly half an inch in some cases., is this normal also...
not normal if you have a good plasterer
perhaps he had a bad back and found it difficult to stoop?
Plasterers are not machines.
All plastered walls have waves, none are perfectly flat.
However there is a limit to just how wavy... :?:
Did the plasterer skim over existing or did he start from scratch i.e. bare brickwork or new plasterboards?
no this is not normal its plain lazyness its where the plasterer hasent bothered troweling the bottom of the wall resulting in uneveness and the curves you are on about could also resemble clumps any good plasterer will tidy up the bottom of the wall with his trowel
also if you have waves in the wall it looks like he may not have crossed troweled it, and the gaps at the bottom of the walls you have are also from his lazyness, its things like this that makes the difference between a good and a bad spread
