Plaster skim corrode copper?
6 Feb 2010
Blackpool
Can finish plaster/ plaster skim corrode copper, if any is dropped on a pipe and not cleaned off?
Not generally no. Lime based cements in the other hand are an issue, but general finishing plaster should be ok
thanks just noticed pipes coming down from the ceilings plastered up to as well.
what could be used as a sealant/ mastic to seal around a pipe if it hasn't been plastered up to?
So is it gas then?
Still good practice to sleeve it!
Not essential but... Just my observation :sneaky:
What's going to be done with the block wall? Dot and dab?
