I recently purchased an old flat and removed the old kitchen splashback tiles. Then above it the plaster skim layer (I believe) simply peels off and leaves a very thin layer of something behind (PVA maybe) and then the old plaster which seems in good condition.
What are my options for redoing the skim over the old plaster and what are the steps involved?
Can I simply put 9mm plasterboard over the old plaster?
whats you final purpose for the wall surface?
is that a gable wall or a party wall or similar?
you've got two options and both involve hacking off back to the rough rendered background.
the wall unit(s) should also be removed for the job.
1. after hacking off then glue 1/2" plaster board to the raw background - dont trust the existing coats of skim etc. this will make the upper surface proud.
2. make good the hacked off exposure and then skim after prepping with SBR.
I would like to paint it white. It is a roof flat, but that wall is a wall between two flats in a terrace.
With regards to the second option, is there no option to skim again after removing the skim? Or do anything that doesn't involve hacking much just so that I can paint on top of it.
Thanks, I decided to go for option 1 as the plaster was clearly blown.
The plaster under the window has metal mesh. Is there any chance the plaster could have structural properties or is it safe to remove it from around the window and roof panel?
use a knife to cut all inside corners before removing the plaster.
i dont understand which panels of plaster you now want to hack off - can you mark them/crayon on a pic?
leave the mesh alone after exposing it then post pic of all exposed surfaces..
theres a wood block - maybe it ties in to a rafter. maybe the mesh has some tie-in purpose too?
is the roof window tight against a parapet on the party wall?
plaster is typicly non - structural.
