Basically because it is easier to get a flatter, uniform finish with two coats.
If you are doing large areas, it is actually quicker and more productive to use two coats.
A small cupboard wall or ceiling, with no scrim to cover can be done in one coat.
The purpose of the first coat to is even up the surface, cover any minor holes ,hollows or joints, fill in around beads etc . When this goes off a bit, you can flatten it - this then gives you a nice background for your second coat.
If you try both methods (one coat v 2 coat) often enough, you will find two coat is by far the best way to go. Try doing reveals or any place that is heavy in one coat, and watch the finish sag as you try to get a finish on it .
Also one coat work tends to look worse as fat is used to fill imperfections as you trowel up, rather than another coat of good finish (ideeally a fresher mix)
You don't use any more material, as if one coating, you still have to put enough on to fill the scrims, beads etc. As a matter of fact I probably use less finish two coating than alot of lads I see trying getting away with just the one.
You can get an acceptable(but not the best) finish, but you have to work harder at it, and having a trade is about making things easier.
