I've pulled down a plaster and lath ceiling in a Victorian house (1890) as parts of it were coming away.
Sorry, that this is so long, but I thought extra detail would be useful.
I want to plasterboard it, but some of the joists are slightly different levels, only about 5mm out vertically. They are pretty bob on horizontally in both dimensions.
However, the spacing varies quite a bit and one joist (2nd from a wall) is warped. It looks from the mountings of that joist, which are fine, that the joist was warped when the Victorians installed it. Cheapskates
The room is 3.85m*3.12m with a chimney breast, which has a constructional hearth supported in the joists above. It's a 1st floor room, with 2nd floor room above.
I wondered what would be the best way to plasterboard this?
Install a new batten framework, screwed to the joists, with relevant packing to get it level?
Or is it possible to noggin the joists? Possibly a tedious job?
If battening, what would be a good size for the framework? As it's attached to existing joists, I'd expect the framework could be relatively light, relying on the existing joists for support i.e. as small as 1"x1" or would a greater dimension of battens be needed? I'd like to keep the depth to a minimum to maintain ceiling height. It's 2.85m high, but I don't wanna waste space unnecessarily. Would; 1" depth x 2" width; be better to provide decent (wider) fixings for boards, and/or is 1" depth just too lightweight?
The joists are actually in pretty good condition, apart from exceptions above. They vary but are 55-65mmX165-175mm.
I've not done anything like this before, but think it within my skill range.
I'd like to use tapered boards, as I fancy DIYing all of it. If the finish is unsatisfactory, I'll get it skimmed at some point in the future, but currently finish is not paramount.
I was interested in the Gyproc 4TE boards which are tapered on all four sides. Because I'd like to avoid the problem of the butted square ends I'd inevitably get on a ceiling which is over available board sizes; 2.4m or even 3m.
Are these boards available for a reasonable price. They seem to have pretty limited availability.
Do other manufacturers produce a 4 tapered edge board? I could only find the Gyproc product.
Thanks for any advice you could provide.
