Plasterboard over airbricks
24 Jul 2007
Buckinghamshire
I am plasterboarding an external wall which is now inside a new conservatory. This wall has two airbiricks below the original wood floor level which are level with the conservatory floor. I.e. there is a step from the original house to the conservatory the depth of the air brick.
The wall is on the north side side of the house. There are two open airbricks to the south side & one on the west side. The house is a typical 1930s semi.
What considerations do I need to make if any to these airbricks? Can I plaster over or should I cut around the airbricks ?
Thats what I thought & was planning to do.
I have a sub question- do regulations allow me to ventilate the floor into the conservatory. It doesn't bother me, but I'm thinking of how a surveyor may look at it if I sell the house in the future.
venting into a conservitory is fine
except may cause a draught especialy on windy days via any other connected vent going to the outside
Your air bricks wont work as they should not be going into a sealed conservatory. Who ever fitted the conservatory should have moved or installed new air bricks to the outside of the building. Guess you have concrete base? Well they should of put vents under base to outside connecting the old vents. In order for the vents to work they must have air flow ( outside air flow) to opposite sides of the building. If not you will get dead spots leading to damp and many other problems.
