    Dismiss Notice
Plasterboard staggered?
Discussion in 'Plastering and Rendering' started by xdrive, 27 Jul 2020.
  1. xdrive
    xdrive
    2 Mar 2019
    199
    Thanks Received:
    Country:
    Hi
    I have been boarding up my dormers with pink 12.5mm boards.
    On front dormer the boards span to centre dormer rafters. Do I continue with seem in middle or do I make more work by adding 3 boards so the seems don't meet.
    Regards
  2. Sponsored Links
  3. bennymultifinish
    bennymultifinish
    21 Apr 2020
    1,917
    Thanks Received:
    291
    Country:
    doesn’t make any difference.
    as long as the edges rest on timbers.
  4. xdrive
    xdrive
    2 Mar 2019
    199
    Thanks Received:
    Country:
    how about on stud wall. Do you hang vertically or horizontally?
  5. bennymultifinish
    bennymultifinish
    21 Apr 2020
    1,917
    Thanks Received:
    291
    Country:
    either, depends on the wall. and what board sizes work best
  6. xdrive
    xdrive
    2 Mar 2019
    199
    Thanks Received:
    Country:
    This is at an angle. Ceiling above staircase.
    Is this joint OK as there is a bit of a gap.
    Or should I have done a mitre joint. Bit more difficult.
  7. bennymultifinish
    bennymultifinish
    21 Apr 2020
    1,917
    Thanks Received:
    291
    Country:
    it’s not great but will be fine when taped and skimmed. you could fill it out before skimming.
    • Thanks Thanks x 1
  8. xdrive
    xdrive
    2 Mar 2019
    199
    Thanks Received:
    Country:
    I've had dormers and gable wall built on my semi. Do I use pink plasterboard on Ceilings on first floor. I have used pink in dormer and around steel beam. Also put firedoors in too. Thanks
    @^woody^
  9. bennymultifinish
    bennymultifinish
    21 Apr 2020
    1,917
    Thanks Received:
    291
    Country:
    if you are now using the loft space as a living space you can do but they are much dearer and heavier.
    building regs may insist on it as well as fire doors with closers and a whole host of other stuff.
    • Thanks Thanks x 1
  10. Sponsored Links
  11. xdrive
    xdrive
    2 Mar 2019
    199
    Thanks Received:
    Country:
    Bco says no need. Just use normal boards.
    But I'm sure I read somewhere you need to.
  12. bennymultifinish
    bennymultifinish
    21 Apr 2020
    1,917
    Thanks Received:
    291
    Country:
    i think its only essential in hmos.
    go with their recommendation.
    although the latest conversion i did bc insisted on fireboard on 1st floor with fire doors closers and wired in alarms.
  13. xdrive
    xdrive
    2 Mar 2019
    199
    Thanks Received:
    Country:
    Done the wired alarms. Thanks for your help
  14. frutbunn
    frutbunn
    22 Jun 2020
    441
    Thanks Received:
    79
    Country:
    Fire resistance won't be required to the dormer unless on or close to a boundary, self closers are not required any more in domestic situations apart from internal garages and doors to flats opening into protected corridors, stairs etc
    • Like Like x 1
  15. Notch7
    Notch7
    15 Sep 2017
    19,573
    Thanks Received:
    1,368
    Sussex
    Country:
    That must be fun gating fire board upto dormers. That stuff is heavy
  16. frutbunn
    frutbunn
    22 Jun 2020
    441
    Thanks Received:
    79
    Country:
    Fire board cannot be insisted upon, only periods of fire resistance, however this may mean additional or thicker boards will be required if using ordinary boards.
  17. frutbunn
    frutbunn
    22 Jun 2020
    441
    Thanks Received:
    79
    Country:
    In most domestic situations you need 30minutes fire resistance apart from the roof members, how you achieve this is up to you, you do not have to use fireline boards
Loading...
Share This Page
