Good evening.
Thank you for reading.
A final section of plasterboard is being fixed in place but unlike the other boards fixed flat securely, the final board is against a slightly uneven wall which, with the insulation underneath, means that the board is slightly curved outwards from top round to bottom. The galvanised nails are sinking into the board.
Is there a standards solution for this? Perhaps there are galvanised nails with bigger heads? Currently 40mm nails with normal size tops.
