I have a small room that is 3m long by 2m wide. It is in the eaves of the house so 0.5m is a flat ceiling, while the other 1.5m slopes at a 45 degree angle. The plaster and lathe ceiling is already split near the joint between the two halves and the ceiling is very uneven where it has come away from the joints in places.
If I was to replace it with plasterboard, is there any way I can create a flexible join between the two halves of the ceiling, given it would need some sort of skim coating?
I have thought of putting further screws in the joists to minimise movement and then to fill any cracks that appear in the skim coat with a flexible filler.
