Hi, my house is 200 years old and I am working to a budget. The bedrooms on the top floor have sloping walls on two sides, which are the actual roof. The plaster is literally being held up by old chip paper. I have removed the paper and the plaster is ancient lath and plaster and needs completely replacing. There is no insulation and if I pull the plaster off, I will see just batons and roof tiles. The tiles on this part of the roof are kent pegs and on the top of the house is slate. I would like to insulate before using plasterboard. What should I use, bearing in mind I have little space between the tiles and the new plasterboard.
Any advice would be much appreciated.
Thanks,
Phyl1
By the way, the house is not Grade 2 listed
Thanks,
Phyl1
