Plastering old walls
10 Dec 2005
Hi
Can anyone advise me on what needs doing
I have recently started stripping the wall paper off the walls in an old terrace house there are 6 layers in total with a skim of plaster after the third layer of wallpaper!
After all the the wallpaper is off the plaster is falling off parts of the walls in places. What do I do?
Do I hack off the old lath and plaster completely?
Or is it possible to plaster over when in a bad condition?
Or could I not have even bothered to strip the walls and got them plaster boarded over?
Please help I don't want to waste time stripping walls and hacking off plaster un- necessarily
I has the same problem in my house so I took all the old crap off in some parts right back to the brick and then got it all built back up then skimmed.
Looks nice now.
Probably the best route. If the plaster has blown in some places it won't be long before the rest might do. Rip it all off and put up plasterboard in it's place, fixing them to the existing studs.
You could just plasterboard over the existing stuff using dot and dab, but if some of it's already coming off you might as well go the whole hog plus a few trips to the local tip. :) Makes it easier to put up the plasterboard when you can see the studs.
