Plastering onto plastic closers or metal?
4 Jan 2009
True North
I have 2 items i'm unsure about plastering onto
1.What is the best way to cover plastic cavity closers on my internal window reveals? I'm sticking boards over some as i can adhere to the inner block but one room it has to be bonding,browning or something else?
2.whats best to plaster internally to a metal catnic lintel?
Any suggestions?
Overboading is the best but Bonding plaster will take well to plastic cavity closers; fix a lump of metal lath over the reveal first or it will probably crack later.
For the Catnic (underside I assume), 2 layers of wallboard is best (fix with a trade grab adhesive) to prevent cold spots and then skim. Bonding will also stick to steel (overhead is generally a challenge though) if you give it a thin skim coat first & then overcoat after the skim has gone off. A bonding agent will help as suggested; 1:1 PVA/water with some sand (or Bonding plaster) thrown in, leave to dry thoroughly overnight.
thanks alot mate,i'll follow that advice and use board.ill source some metal lathe tommorrow at my builder merchants
