Plastering Quote
22 Aug 2012
Buckinghamshire
Folks,
Am in the process of renovating our new house, and have had a quote for replastering the whole house:
To re-board all ceilings with "artex" finish. Tape joints an skim......£1650
To make good, prep and skim all walls..........................................£1800.
This covers labour and materials.
The house is 4 bedrooms, all the walls are stripped, the electric/water pipe chasing we've had done has been filled in so the walls are in reasonable nick and ready to go for the most part.
Size-wise the bedrooms are roughly 13" by 11", 11" by 9", 9" by 9" and 9" by 8". Downstairs the lounge is 20" by 12" and the dining room is 11" by 10". On top of that there is the downstairs and upstairs hall areas which are reasonably sized. Plus they said they would make the bathroom walls ready for tiling where the old tiles had been taken off.
I think this sounds reasonable and from the research and rough guides I've found on the web it is backed up, but just wanted to sense check...?
Please let me know your thoughts! Thanks.
you should get 3 or more quotes from different plasterers that have good reputations. That way you know whether that is a reasonable price or not.
Once you have the quotes consider carefully which one to choose, dont just opt for the cheapest consider, experience, how long it will take them etc
Thanks - and yes under normal circumstances I would.
Unfortunately time pressures are rather extreme, and I just wanted to sense check it with a finger in the air if anyone on here was able to do so...ie that's too cheap, that's about right, or whoa that's pricey!
I am trying to get a handful of other quotes in parallel with this, but was hoping the good people of this board might be able to give some additional guidance / sanity check.
Sounds reasonable to me. Just add the stipulation that you want to see what one room looks like before they go onto the rest. If they are rubbish then you can show them the door.
