Plastering
14 Mar 2006
West Glamorgan
I am in the middle of redoing my bathroom, I have taken the tiles off the walls and it has left a lot of tile adhesive behind, have tried chipping it off but it is like stone. I have decided to skim the walls with finishing plaster.
There is a lot of boxing in around the soil stack, I am concerned that if I skim it all, the movement where the boxing meets the wall will cause some ugly cracking!
Is there something I can use to reduce the chances of craking or movement between the two (some sort of special beading perhaps?) or am I worrying about something that will not happen anyway?
I dont really want to put up plaster board all the way round and then plastering that as my bathroom is very small already!
Have you tried a steamer on it? Should soften it up enough to remove with a scraper.
Symo
Excellent, thank you for that!
I will definitley give it a try tonight! It Should cut down on the amount of plastering I have to do!!!!!
With regard to the boxing in (think it is plyboard), could I just seal it with PVA and skim that up to the existing walls, so it stands out a little less? I want to paint the walls. Or will the movement produce cracks?
Just make sure the boxing is screwed up nice and tight. You can bond it and skim it as long as it's decent WBP ply. If you don't know what the boxing is made of then just screw a layer of board over it and skim that.
Symo
Happy to help. Nice to pass on some of the many, valuable, lessons these forums have given me.
Symo
