Plastic cap on radiator valve
23 Apr 2011
Derbyshire
screw in the centre chewed up, is there a better way to get them off other than hacksaw? (id like to save the cap)
thanks
valve weeping underneath...
Most valves (not very old imperial ones) have M4 screws. Drill through centre of screw with a 3.2mm (smaller rather than larger if you haven't got 3.2) and use an "easy out" to remove screw. If screw is cross headed, you can try using a countersink bit to centralise a start for the 3.2mm bit. New M4 screw (preferably brass) on reassembly.
Alternatively, as above but use 3.3mm drill (M4 tapping size) through screw into spindle, then large drill to remove head of screw, then re-tap hole in spindle M4.
Since the valve is leaking and they only cost about £3 then I dont see much point of fiddling with it.
Most DIYers dont have taps or taping size drills and they would cost more than £3 anyway!
Ive had a play and turned it down (since the plumber came) and im hoping its stopped it weeping?
has in the past with the same type of valve
if not will try to drill it out.. :)
