Are different brands of barrier pipe & fittings interchangeable? I know the pipe sizes are a standard and the correct inserts for the type of pipe need to be used but are there any other problems I haven't thought of?
Always use the pipe manufacturers inserts, which you've already mentioned. Other than that there should be no issues.
No, never mix components from different manufacturers. If you need to join two different systems, use a normal compression fitting.
This is the correct advice from the manufacturers.No, never mix components from different manufacturers. If you need to join two different systems, use a normal compression fitting.
Correct information?
No, they say this so you don't use perfectly acceptable leftover fittings.
They want you to buy and use theirs.
We always say use the pipe manufacturer's insert.Hepworth Insert with Polypie pipe
So, copper tube made in Liverpool, the West Midlands, Germany, China or Bolivia with whatever tolerances can all be used.
Why, because Wavin don't make copper tube.
Not when it comes to the OD they are not.The fittings are manufactured to each manufacturers design and specification
15mm OD plastic (PEX, PB) is 15mm. There is nothing on one manufacturer's outer surface to make another manufacturer's grip and O rings not sit correctly on the pipe.
Do you drink Evian water, by any chance?
Who's not reading or digesting now?I see you didn't comment on the "Typical Situation" that I posted or answer the question that I posed.
The only problem with tolerance will always be the ID of the pipe.
