Hi All, can i take your advice on something please?
I have a Main Combi Eco 30 and it seems like my plate heat exchanger is clogged up (from researching symptoms). I've bought a replacement online and want to have a go at replacing myself, so I know for future reference too for cleaning/ maintenance.
If I run through the steps I am thinking can you please advise if I've missed anything out or doing incorrectly.
1. Switch off electric to boiler
2. Turn off all pipes below boiler
3. Remove Cover
4. Drain boiler only (not full system) using white release valve with bucket underneath.
5. Remove (plate) heat exchanger screws, then unit itself. (Is there anything else I'll have to remove first to get to it?)
6. Replace with new HE and screw back in.
7. Refill boiler using normal filling loop.
Do I need to know about filling or releasing air? or about greasing any parts? or any other tips/advice?
Thanks in advance guys,
3. Remove Cover
