plate hex hard or easy????
21 Nov 2009
Leeds
hi guys
can anyone advise me on how easy it is to remove a plate hex ona vokera linea 730 and also what to use to clean it and neutralise it etc
its running hot and cold every minute or two
also would you change the rubber seals???
cheers in advance
If the hot water is fluctuating Hot/Cold it is unlikely to be a Plate Heatexchanger fault, i would check the Thermistors & wiring before going any further :wink:
ok will do, cheers
but out of interest what if anything should i use to neutralise after cleaning??
could i swap thermistors over just to try/confirm??
Linea plate heat exchangers are a piece of ****. Massive amount of room behind the heat ex to remove it. Just 2 screws to undo. Replace the 4 orings and smear of silicon grease on refit
