I have a Halstead Finest Gold boiler in my house which has been finding it hard to deliver DHW. I have gradually turned down the DHW stat as when the taps are turned on fullish, the boiler cuts out and then refires 10 seconds or so later and repeats giving hot/cold alternating water.
Recently, I had noticed that an upstairs radiator was colder in the middle and decided to put some degunking jollop through the system. Unfortunately, the boiler can now be heard (I can't really describe the sound but it is just obvious it is there!) and the DHW is far worse.
CH is working fine but DHW cuts out after 10 seconds or so even when a tap is only just open. After a couple of restarts it will lockout and the overtemp button will pop out underneath. A little bit of dirty water will also momentarily dribble out from the front, left side underneath too when it does this.
From reading past posts on here, it would appear that the cause is a clogged HE. I presume it is the DHW (or plate to plate?) HE? Is there anything else that could need cleaning or replacing too at the same time?
Thank you.
Thank you.
