Hi
I have a baxi solo 2 pf boiler, i have had problems with it in the past, so ill give a little history, before i tell you about the new problem
First fault was a dry joint on the PCB, i fix that and it ran fine for a long time
2nd fault was the fan bearing siezing up, i fixed those and it ran fine for a long time, also replaced the pcb at the same time....
Current problem....
Went away for 2 weeks on hols so heating hasnt been on at all for 15 days, was working fine before we left, got back yesterday turned on water/heating, boiler clicks and nothing else, i removed terminal box from pump, and there was no voltage going to pump.
got the Mrs to turn heating/water on while i have an AVO on pump terminals, voltage comes on 230v , pump runs for a split second, then voltage turns off.
any ideas?
Current problem....
any ideas?
