Hi, as you can see I have just signed up as I deffo need some help! so im hoping someone out there can help me! to cut straight to the point I live in a flat with electric only as power source, therefore I am on an off-peak & on-peak econo 7 , I have a twin emersion heater (I think) which heats up the tank over night on the cheaper tariff, there is also a boost function on my hostmann controll panel, anyway my problem is that when using the boost function, usually when I get in from work for a shower as there isnt enough hot water by this time, all is well! however the sysyem isnt heating up over night as when my wife has a shower first thing in the morning the water is just tepid, I thought in my wisdom that it was the hostmann controller as it must be a good 10 years old, so I replaced it yesterday, programmed it etc, however I used the boost function last night to have a shower and all was well with lovely hot water, my wife came to have a shower this morning as usual and aarrgghh!!! tepid water!!! hence the problem is not fixed!! my only thoughts is that it is the coil feed in the tank???? can anyone confirm this?? I assume the tank is in two sections with a coil feed in each, hence the reason it works when the manual boost function is used? hope someone can help!!
Thnks in advance
Matthew
Thnks in advance
Matthew
