Im really hoping someone could help me with some useful advice. My Glow Worm 30 CXI is about 3-4 years old and two days ago we had no hot water or heating. I went to the boiler to find an F1 fault which the book says is a connector, ignitor or gas supply issue. After a reboot it was back up and running. The morning after the same but this time the external 3A fuse had popped. (the PCB one is fine). The plumber thought it was a blocked condencer outlet or the flue but this does not seem to be the case. The fuse usually pops after about 15-30 secconds of the boiler working i.e it fires ignites burns, pumps and pop.
The strange thing is if i turn the HW and CH off on the boiler and switch it on, it still pops the fuse. I cannot se any sparks all i hear is a click and the fuse is gone (although the click is likely a shut off valve). Ive also turned of the thermostat to see if it was that.
I tried it again this morning with the room pitch black to see if i could see anything, the CH and HW was still off. Nothing, it ran, i waited 10 mins and fired up the HW and it ran then the CH and it ran. About 25 mins in it popped, again with no visible spark just a click. After replacing the fuse again, it went straight away upon switching the boiler on.
I dont want someone to start replacing the pump, PCB willy nilly without isolating the issue. Surely if it were the PCB it would blow the board fuse.
Does anyone have any ideas?
Best wishes
Jon
Best wishes
Jon
