Hello i really hope somebody here can help.
I have moved into a new apartment 2 weeks ago and i have not had more than 10 minutes hot water at any time apart from between 1am and 7am.
I have a Tribune Premier water heater and have had an electician out who has tested everything and can't find out the problem.
The heater is a storage heater and should heat through the night and store the hot water for use during the day (as i understand it but this may not be the case). When the heater is on during the night i get hot water fine but as soon as it hits 7am and it turns off and all the water is cold.
The boiler does have a boost feature but this only gives me a max of 10 minutes hot water before it goes cold again even though the settings are 30 minutes, 1 hour, 2 hours.
I really need some advice on how i can get hot water during the day. Even though the switch is in the on position unless it is between 1am and 7 am the water heater does nothing.
I have had a look and the heater seams to have no timer settings at all. The electrician checked all the cables and all power is getting through and as i said i get hot water fine during the night.
