sounds as though the fault is with this new thermostat.
If you turn the stat up to it's max setting does the heating come on within 5 minutes? Some of the newer stats have a delay period before they send a signal to turn on. (to reduce cycling)
You could also try using a new set of batteries (not rechargable). I have had the odd set come nearly flat that work for an hour or so then cause the faults you describe.
