Hello Everyone,
I woke up this morning noticing that the lights on the 1 & 2 floor done work, I knew it would be a fuse problem, I took out the offending fuse and noticed that it had broken.
I have replaced this with a 5AMP fuse, but what I noticed is that after about 45 – 1Hr, it keeps blowing/breaking, I have changed it 3 times now. Before changing it 3 times, I unscrewed the switches which I believe could be dodgy, I looked at them and made sure that all the wires were in the right places.
After opening 3 switches, after every switch open, the I redo the fuse and plug it in, then after 30 – 45 mins it breaks again, now there is not point changing the fuse, as there is clearly a problem somewhere.
One thing is that all the bulbs for these switches are all energy savng bulbs, not sure of that implication this is. Does anyone know any tool I can buy from wickes/B&Q that will point me to the faulty switch/circuit.
As I am lost for ideas now, if I change the fuse it will break again. If I fit a 15 AMP switch for this 5AMP fuse, will this not make it break again ? I have heard it can cause an explosion, but I don’t know what to do now.
