Can I please have some advice from you.
In an earlier thread I mentioned I wanted to install some wall mounted taps, I have now seen these in my local plumbing shop, Niagara Pixel tap, fourth on the page, Niagara Pixel 3TH Wall mounted Basin mixer.
http://www.discountedheating.co.uk/shop/acatalog/Niagara_Pixel_Tap_Range.html
The plumber came the other day and did some piping (he said was first fix) and will come to do the second fix again when the plasterboards and tiling is done.
He has taken two pipes out for hot and cold and there is a distance of 9 centimetre between the two.
The plumber was hired by the builder who is doing the extension work. The plumber I think is trying to make it easy for him rather than what I would like and was saying I would not be able to install a mixer and went into so much technical details so to confuse me as I have no knowledge of how plumbing works. He is advising me to have two individual taps and said only normal taps can be used and he will make them wall mounted.
Can you pleae advise if there would be a problem having this taps installed.
