Hi - i need some help. I have to install a circuit for a practical assesment and have to draw a circuit diagram 1st. The circuit is 2 2way switches and 2 lights - i can draw a diagram of 2 switches and 1 light but am confused by the 2nd light.
This is what i have to do - the work requires the following circuits to be connected to a supply within an existing trunking and tray installation
1. two - way switched lighting circuit
2. radial small power circuit consisting of four switched socket outlets
3. single radial small power circuit using steel wire armoured cable
circuit 1: the installation requires pvc single core cables installed in existing metal trunking and pvc conduit from the trunking to the luminaires
circuit 2: the installation requires 4xtwo gang switched socket outlets. These are to be connected in a radial circuit and the fourth as a spur off the middle SSO. The cabling between the CCU and first SSO is 2.5mm sq. pvc singles installed in the existing trunking with the new 20mm diameter black enameled metal conduit between the trunking and the first SSO. The remaining wiring will be surface mounted in 2.5mm sq pvc/pvc multicore cable (6242y).
circuit 3: the installation requires a 13A switched fused connection unit connected to the CCU using 2.5mm sq pvc/swa/pvc multicore cable fixed within the existing tray installation
I have to do circuit diagrams of all 3 circuits before i start.
Suitably rated over-current protection devices must be selected for the circuits and cable size where not stated
theres a 3d drawing of the installation bay as well which i will upload with this post and the 2 switches for the lighting circuit are marked A on the drawing and are just above the metal trunking.
Any help is greatly appreciated!
