Plug in fluorescent fitting
20 Nov 2005
Kent
Anyone seen one of these before?
Its in the kitchen of a house I'm quoting on. If you can't tell from the picture, its a standard fluorescent fitting which is then plugged into the bayonet light fitting.
My initial thought was that it would no longer comply as I understood plug in adapters were generally frowned upon, but then the argos site has this which seems to be a more modern replacement.
Given that I now see no reason to insist/suggest it is changed (apart from aesthetic/taste reasons :lol: )
Anyone disagree? I will see if I can open it and inspect the internals but given an insulation resistance test is unlikely to do it much good is there any other test that I should be doing on it?
Gavin
YUK! argos used to sell these, exactly like the one in your picture. Hideous. Do everything you can to try and accidentally damage it :lol:
Are you sure that the old fitting in your picture is double insulated?
Not seen one in a good long while, but not the first :lol:
have a look at the lampholder for any numbers ad see if you can google some design specs for weight..
as long as it can take the weight, i can't see why you shouldn't treat it as a lamp..
Looking in the regs, flex can carry quite a weight, so I would have thought that this would be no problem in a batten l/h....
These are, to my knowledge, DI.
for the amount of light it puts out, and the cost efectiveness of it, just suggest that they change it for a CFL lamp about 100W equivalent..
or tell them that you're going for a cup of tea and that it would be better as a normal bulb when you get back..
what they put in after you leave is up to them... :twisted:
If its a manufactured item and not a diy item then chances are it is certified already by the manufacturer, being a plug in job it is not covered by the scope of the regs that you are concerned with.
yep,
well the job is an old dear who likes it, so I will check it out and see if I think its safe - in which case she's the one who has to look at it every day :)
So this is effectively the first generation of 'compact' flour lamp I guess..
How long ago were they on sale in Argos?
Gavin
