Plug socket in loft?
20 Nov 2006
Bradford
I want to install a plug socket in the loft. Can I run off the lighting circuit that is already there?
Many thanks
No you can not go from the lights the power point needs to be in the ring main same as the rest of the power points
Lighting circuits are rated at 6 amps and you want to draw up to 13 amps QED
crafty1289 said:
There are no regs that say you cant put a 13 amp plug on a lighting circuit.
Depends what it's for. If you just want it for an aerial booster, you could fit a 2A socket.
