L
longdogs
Did anyone hear what the problem was that could affect 3.5M homes. I just caught the last of the story on the news yesterday. All I heard was that something plastic had melted
The plastic water tank wouldn't "melt" at 100°C, but would soften. The real fault was that the tank wasn't properly supported which could result in a distortion of it's shape when softened and spillage of very hot water. So are those responsible for the shoddy tank installation going to be held responsible?boiling water was venting into the cw storage tank, which wasn't properly supported. the tank started to melt, thus leak.
I'm assuming that the tank wasn't supported by a level, continuous base as it should be. Perhaps it was resting on a couple of battens. That makes a lot of difference to how the tank behaves when full of very hot water.Chris so how are the sides of the tank supposed to be supported the amount of heat that went into this tank would just collapse the sides and not just the bottom if it was not on a tank stand
You're right. I'm assuming it was a similar scenario. Possum-jenkins said that the tank wasn't properly supported too. Anyway it all goes to show that it's foolish to comment without first getting your facts right.I think you may be confusing this with an accident in 2002, (in Portsmouth?) in which a woman was killed and her partner seriously burnt. That was a modern tank, but wasn't continuously supported on a WBP plywood. That tank collapsed, but would probably have remained intact if it had been correctly installed.
That sounds like a bunch of nonsense.bpowell555 said:The way to cool it down was not to run the hot water, but the cold![]()
