Plumbing in a mixer shower and bath connections
22 Jul 2006
Hi all
The missus has been nagging me for a mixer shower and P bath.
Our old bath has the taps under the window, so we had to go for a right hand P bath.
This will be on the opposite wall facing, behind the door.
My dilemma is plumbing it in and how to go about it, i can solder pipe etc, but it where to run the pipe and then finally connect up.
I am thinking of running pipe work from my existing feeds on the original pipework at 150mm centres under the bath, up to the mixer shower soldered connections with an isolation valve on each, but this is where i am getting frustrated, then i have to make connections to the bath taps with seperate isolation valves on the same run but they also will be at 150mm centres, so what is the best way to connect these pipes, as shower pipes and bath pipes will be to close to each other?
Bath taps would be 180mm centres ,and many mixer valves are 150 mm ( but not all ). Route pipes to avoid baths feet horizontally ,bring up at 180 mm centres ,to align with tap holes. At any convenient position on horizontal runs ,T into and run two feeds to shower at whatever centres ,150 maybe. Hope that makes sense. I assume you are taking the shower pipes into the wall at some point lower than the bath rim.
Hi Terryplumb
Yes m8 I am taking the lower pipework into the wall at 150. The missus picked the mixer tap for the bath and it was saying it was 150 centre, thats what confused me, must have been a typo error.
Thank You for your helping me out.
Best Regards
The holes in the bath are 180 mm apart. So in the unlikely event that you have a mixer tap for the bath that has its tails at 150 mm it ain't gonna fit !! Probably a misprint as you say ,but these days with internet purchases from around the globe , nothing surprises me. Maybe bath taps from Tibet are 150 mm centres as standard. Who knows !! Regards terry
Use these, instead of standard ballofixes...
https://www.bes.co.uk/lever-operated-isolating-valve-black-handle-15mm-chrome-23660
You'll thank me for it one day :sneaky:
I would suggest lever valves but space sounds like its tight! You could T off the main feeds further up the pipes (under the bath) where you have more room to add your connections and then just have 2 unfettered pipes in the vicinity of the bath taps, going into the wall and up to the mixer.
It may be a 150mm centre mixer but it then sits on offset leg pillars that are angled in from 180mm to 150mm for the bath deck. Just check what you have first to get the pipework right
