Hi all
I am planning to convert a section of my garage into a utility room, which will have at least a sink and a washing machine.
I am fairly confident about getting the water supply pipes into the right position, but have a few questions around the waste pipes...
1. What dictates whether you will use 32mm or 40mm waste pipes?
2. My manual says it is "almost always all right" to drill a hole through the wall and connect the waste pipe directly into the 110mm single waste stack outside using a boss. This is what I'm planning to do, but does anyone know under what circumstances it isn't all right?
3. My manual says that a "gap filling solvent" should be used to make sure the connection (described in 2) is water-tight. Can anyone recommend any such solvent?
3. (probably a silly question!) What is the best way to get a 32mm or 40mm (depending on the answer to 1) hole through the wall? Can you get masonry drill bits this size?
Sorry for the novice questions! I really appreciate any who takes the time to read my post.
Kind Regards
Jon
Kind Regards
Jon
