- Joined
- 22 Feb 2006
- Messages
- 391
- Reaction score
- 27
- Country
As mentioned in a previous thread http://www.diynot.com/forums/viewtopic.php?t=204540 my central heating system is mysteriously losing pressure which, I believe, is probably water leaking under the floor somewhere. I feel this is likely because this happened 18 months or so ago and I had to rip up the hallway laminate and dig up the screed to find the leak. The property is five years old and I can only guess the pipes haven't been protected too well by the builder. It is a long bunglalow, so maybe it's moving too much? As explained, I cannot find any leaks above ground and rather than ripping up all the flooring in a heart-breaking, piecemeal fashion, I was wondering if it would make more sense to leave the old pipework and run fresh pipework to the rads, etc from above ground, ie through the loft. This is a five-bedroom bungalow. Does that sound a reasonable solution? If this is feasible, what's a (very) rough ballpark figure? I can clear all the loft insulation, channel walls, etc, or must I have the pipework showing everywhere (that was the wife asking that question...).
* Have checked AAVs, relief valve, all rad connections and the pressure vessel is holding it's charge, so I'm guessing it can't be leaking internally. Boiler's (Firebird oil burner) dry underneath, motorised valves are dry. Pressure drop is quite alarming when cold, but largely fine when hot, Currently just running around a leak sealer to see if I can slow things down. Timing isn't good!
Cheers in advance
Cheers in advance
