Plumbing in American style Fridge Freezer
1 Oct 2006
Sheffield
I've recently taken delivery of an American style fridge freezer with an ice maker that needs plumbing in. The FF came with a good length of 6mm OD plastic pipe. I have to marry this up to a standard 15mm isolating valve (with handle). I'd appreciate any advice on the simplest way of getting this connected up.
Cheers!
Dan_Robinson said:
Did it not come with UK fittings then?
Well it came with a connector that has a 6mm push fitting on one side and a 1" ID thread on the other but since I'm trying to mate to a 15mm isolating valve then this doesn't seem to help too much. Thanks for the link.
PS, the isolating valve is compression both sides.
_______________________________
Lynda, moderator
please use the
button
yup - ours came with a fitting that connects to a standard washing machine outlet valve!
Allows you to isolate the supply so you can change the filter!
Dan_Robinson said:
Did it not come with UK fittings then? If not them you need this.
That a very usefull link Dan ;) ;)
What the OP wants then is a Legris 1/4" mi x 6mm plastic.
1No 1/2" x 1/4" brass bush.
1No 1/2" x 15mm Endex N7 femail adaptor to fit the isolating valve
