Plumbing stacked washer from new utility
It looks like the type of reducer fitted to 100mm Vitrified Clay Drainage, (Hepworth HepSleve or SuperSleve), so may be worth bearing that in mind when looking for a replacement. If you can check the drains outside that may confirm the material used. Just be careful removing/refitting cap is it's a cut end of pipe sticking up, the edges can be razor sharp if not chamfered properly when installed.
