I want to put my washing machine in the same big cupbaord as the cold water tank. The problem is that there is no drain in that cupboard and i'd rather not drill through the wall.
The water tank overflow already goes through the wall and drains into the top of the bath next door. It aint pretty but its there, and its a rented flat.
What I would like to do is attach the washing machine drain hose into the existing 22mm pipe that goes through the wall.
I know thats pretty unconventional, but as long as i have a one way valve above the place where I plumb in the washing machine hose I don't see a problem with the washing machine filling the tank through the overflow, and I know you are allowed to drain a W/M into a sink/bath.
So I think I need to cut the 22mm pipe, stick in the one way valve, stick in a 22mm T joint below that and then use a jubilee clip to clamp the washing machine drain onto a short pipe coming from one end of the T.
Whaddaya reckon?
If you wanna picture I just drew of it I can email - but i can't figure out how to attach it to this post
[/img]
Whaddaya reckon?
[/img]
