Plusnet...
11 Jan 2004
...are ditching landlines once FTTP comes.
What are Plusnet customers here planning to do, or have done already?
The choices as I see them are to move to another provider who offers both BB and phone via the same service/ router.
Or, keep PN for BB and employ a VOIP service for phone access.
Or did as I have when moving to Plusnet from Talk Talk:
Ditch the landline altogether and use our mobiles (via WiFi calling if necessary).
NB that was FTTC (SOGEA to be more precise)... FTTP is coming soon.
Talk Talk and BT/EE offer the <Digital Voice> service on their modem-routers via a BT phone socket (and/or DECT connection). Plusnet would require another bit of kit to do the VOIP bit.
All will need some sort of battery backup when the mains power fails.
1. Accept the transfer to EE
2. VOIP
3. Forget landline and go 100% mobile
In a few years having a phone tied to a building rather than an individual will be as quaint as a red telephone box.
Thanks for the replies, people.
I forgot to say that this is for my Ma, who is 90 later this year and uses and relies on her landline an awful lot.
She doesn't get on with her mobile very well, so will not be ditching the landline.
Also she has a Carecall unit that will need a back-up in the event of a power cut.
I'd recommend then going for one of those that include the VOIP telephone BT socket line converters in the supplied routers... The path of least resistance.
Ensure Ma is on the ISP 'vulnerable user' register... a short term battery backup ought to be supplied foc, I understand when FTTP happens.
Alternative solutions just read as a pita to be remote-supported (VOIP box and account with a n other provider).
Check with Plusnet website / customer service as I believe they semi-automatically push people to EE when they want to retain a "landline" phone service. No early termination fees to transfer (if applicable/in contract with Plusnet).
Note that to connect from the router BT socket to the house phone extension wiring may need an extra step (that may or may not be included in the FTTP installation)... someone here may know for certain (MSE forum is worth looking as well).
Check the Carecall will work on a Digital Voice line (or if it needs upgraded/changed in any way).
Be prepared!
>> Snip<< Check the Carecall will work on a Digital Voice line (or if it needs upgraded/changed in any way).
Be prepared! >>unSnip<<
That is the most important step - do it first, NOW, Today! - Both in writing and by a 'phone call or more.
Carecall 'should' know who provides the best Router and VOIP service to work with their kit. Don't leave it until after the conversion is done.
Option 1 then. She will get a letter, a router and a transfer date. They have a vulnerable people help line. My 90 year old father in law was swapped from PN to EE last week. Very straightforward process.
Thanks. She is out of contract, so won't have to automatically be transferred to EE.
My P-i-Ls use EEs mobile service, having moved from Plusnet Mobile and they are very expensive and the customer service not so good.
Have looked at Zen Internet, anyone using them?
Thanks Rodders and Diver.
I've suggested she rings Carecall. If need be, I can do it for her when I'm with her. In fact, I'll ring them today and ask what their requirements are.
I have rung Carecall and they tell me that their units have a back-up battery and 2 x SIM cards so that if power goes off, they can be used for 48 hours and will communicate via the SIM cards.
Do check which providers their SIMs are for and then properly check the coverage where the Carecall units are located with phones using that service.
Don't forget that '3' and 'Voda' are the same provider nowadays.
We had to switch over earlier this year. The option was as you say, stay with Plusnet, no landline or switch to EE for a landline. I decided to ditch the landline. However as the young lady said on the call. Have you an alarm linked to the landline. Oh bugger we had. I therefore looked into a SIM based communicator which are readily available. However the mobile signal at our house is dire and is dependant upon where in the house you are. This may seem a bit odd considering the state of the mobile signal, but it generally works providing you don't wander in to dead spot areas. The solution tuned out to be a mobile signal booster which solves our iffy mobile phone connection and our alarm communicator problem. I had to shell out a bit of money though. £150 for the booster and £140 for the alarm communicator. Fortunately we live in a bungalow and mounting the outside booster aerial wasn't too much of a problem; installing the internal antenna was a bit of a carry on regarding access to the roof space. I'm not as young and agile as I was. If you're unable to do this yourself then I daresay a local aerial contractor or satellite installer would be able to lend a hand.
