Plywood Beauty Contest
10 Aug 2007
London
Which of these is the most suitable / least suitable to lay on top of joists to create a sub floor.
  • Standard WBP Plywood
    Shuttering WBP Plywood
    Marine Plywood
    Spruce Plywood
    Formwork Plywood
what are you going to put on top of it?
What room is it?
It's a living room.
I'm going to put down a plywood floor, screwed to the joists, followed by a heavy carpet underlay, followed by a carpet.
[ I am replacing old 25mm floorboards so if choose 18mm ply this will leave a gap of 7mm. I could possibly fill this with some proprietory mineral loaded soundproofing felt or similar , beneath the underlay. ]
Standard WBP then.
Marine is very expensive, the others can have very rough surfaces.
Have a look at some samples in the yard before you buy.
Some spruce ply is reasonable, but some has open knots etc.
