    Dismiss Notice
Plywood on floor
Discussion in 'Floors, Stairs and Lofts' started by DaveOC, 29 May 2021.
  1. DaveOC
    DaveOC
    27 May 2007
    153
    Thanks Received:
    Essex
    Country:
    Hi, I have moved into an old house, the floor boards are OK but a bit old Knackered and gappy, before I put in a fitted carpet I was going to cover the floor with plywood and screw down, my question is can I use thin ply ie 3mm, is there a down side to this or should I make it any thicker.
    Or would hardboard be better?
    Thanks for any advice.
  2. foxhole
    foxhole
    14 Mar 2006
    17,516
    Thanks Received:
    2,008
    Kent
    Country:
    Hardboard is usually used under carpet.
  3. Sponsored Links
  4. ETAF
    ETAF
    24 Apr 2008
    987
    Thanks Received:
    169
    UK, Wittering, West Sussex
    Country:
    i put hardboard down on a couple of bedroom floors quite a few years ago, onto normal wood floor boarding , before underlay / carpet, all seemed fine, moved out of house since.
  5. DaveOC
    DaveOC
    27 May 2007
    153
    Thanks Received:
    Essex
    Country:
    Thanks all, I'll use hardboard, should I use ring nails or screw them?
  6. Sponsored Links
  7. foxhole
    foxhole
    14 Mar 2006
    17,516
    Thanks Received:
    2,008
    Kent
    Country:
    Hammer stapler/tacker is easy option. Short ring nails if you don’t have tacker.
Loading...
Share This Page
