Plywood size
6 Feb 2006
Staffordshire
I'm trying to match some interior plywood to existing. I have measured it and it is heavily painted so I'll have to guess a bit...either 3/8in or 10mm are the round figures closest.
Any ideas where i can get something to match? Is it a common size?
nowadays the 12mm ply i get from my wood yard seems to be 11mm[6mm=5.5]
some larger merchants will have 9mm but suspect it may be slightly under
i dont think you will get 9mm from the diy sheds
get down your local wood store with a sample or tape guy's will not be too phased if you want a look at the stock
