This is a result of a conversation with a retired engineer who has recently moved from a house with TT supply to one with PME supply.
He noticed a very slight tingle when connecting the hose to the outside water tap so went to check the earth rod was in wet ground and couldn't find one. When I told him the PME system "earth" was taken from the supply neutral he sort of went ballistic........and asked what precuations were taken to ensure the neutral would never float.
He has a point. If the network neutral did float all CPCs would float with it and while inside the house would be "Faraday cage" safe external water pipes etc would not be at ground potential.
Is there a maximum permitted neutral to ground and in the event of a fault ( open network neutral and un-balanced loading on the phases ) how are premises protected from thier CPC having a potential far from ground.
