Polypipe 43mm o/d pipe compatibles.
24 Dec 2008
An existing bath waste run is made up of polypipe 43mm o/d 40mm i/d with solvent elbows
I need to make up a replacement run of pipe with various solvent elbows to fit between an existing straight compression coupling on the 43mm o/d (40mm i/d) polypipe and a soil boss compression fitting that I know accepts this size of polypipe. I can't quickly access any local source of the polypipe range.
Can somebody tell me, please, which of the likely suspects (Screwfix, Toolstation, Wickes) have sutable stock, as I am struggling to get the full specs that would inform me.
ie 43mm polypipe-----universal 43mm compression -------NEW PIPES with 5 elbows-----NEW PIPE------existing compression soil boss that takes 43mm Polypipe.
Thanks for reading.
Screwfix stocks polypipe, but no need to stress, all manufacturers solvent weld waste is mutually compatible.
Only when transitioning from solvent to pushfit is a compression fitting needed
Toolstation's own is aquaflow, it's PVC and not ABS like the others. The fittings/pipe seem to be a tiny bit larger for some reason. It does fit ABS but goes on a little loose though does firm up, it's just not as quick a set as ABS normally is.
Hi, did you find an off the shelf solution? I have the same issue, a 43mm waste pipe that I need to connect to a 40mm pipe from a vanity unit?
