An existing bath waste run is made up of polypipe 43mm o/d 40mm i/d with solvent elbows
I need to make up a replacement run of pipe with various solvent elbows to fit between an existing straight compression coupling on the 43mm o/d (40mm i/d) polypipe and a soil boss compression fitting that I know accepts this size of polypipe. I can't quickly access any local source of the polypipe range.
Can somebody tell me, please, which of the likely suspects (Screwfix, Toolstation, Wickes) have sutable stock, as I am struggling to get the full specs that would inform me.
ie 43mm polypipe-----universal 43mm compression -------NEW PIPES with 5 elbows-----NEW PIPE------existing compression soil boss that takes 43mm Polypipe.
Thanks for reading.
Thanks for reading.
