You don't have to be a brain surgeon, just reasonably competent, and RTFM, it's all in thereIt's all a mystery to me, suffice is to say my plumber said I wouldn't have had any problems like this with a wooster, an Intergas might be a rockstar of a boiler with only 4 movin parts.....................but it aint a lot of good if the electronics require one to be a brain surgeon to get the sucker working correctly.
The menus are largely not designed to be used by the customer. The boiler should be set up to work correctly on the system it's installed on by the installer. All you should be expected to do is use your T4. It's not Intergas's fault if your installer didn't finish the job.I have thrown the towel in!, pressing all the menus is a massive pain in the rear end and is not in the slightest CUSTOMER user friendly. An intergas engineer arrives on Thursday to end my woes.
As a customer, I HATE the touchpad menu pressing, the boiler may have the most advanced n reliable giblets inside the box, but I wish I had bought a Worcester Greenstar because the one I had in my last house worked easily with the Salus roomstat n we got along for 7 years without a single problem.
