Hi all
Hope I've posted this in the right forum.....
I'm trying to decide on what to do with my kitchen floor... I found out over the weekend that the base of the floor is concrete - there is then a layer of polystyrene insulation, on top of which is then the main T&G chipboard floor. I don't think there are any joists from what I can see (would there usually be joists in this scenario?).
If we decide to tile the room, the advise we've been given is that it would make a lot of sense to remove the chipboard and insulation and tile directly onto the concrete.
But being a DIY and building novice I'm not sure what th downsides of losing the insulation would be. I'm guessing the room will be a bit colder in winter, but are there any other drawbacks or can it cause any other problems? Is there anything that can be used to add a little insulation back? Will the tiles and the adhesive give any insulation?
And one other question - damp proof course. Is this usually beneath the concrete and if so do I have anything to worry about with regards the damp proof course?
Many thanks
Max
Many thanks
Max
