Hi guys,
Finally got to start my tilling which didn't go too well! Using 7mm thick 200x100 subway, BAL SPF onto Elements backer board with a 8mm trowel.
Laid a couple of rows in the shower and checked the odd tile for coverage. I'd guess I'm getting around 80% on average, even when giving the tiles a little push forward and to the side.
As the coverage was poor I removed the tiles and tried again, but no joy. I'm conscious of the requirement for 95-100% coverage on shower walls, so need to ensure I do this properly.
The adhesive is like peanut butter consistency, troweled onto the wall and then combed vertically at 45 degrees. When laying the tiles, I'm giving them a little push to ensure a good bedding (apparently avoids air pockets).
The tiles also have an annoying .5mm ridge around the edge, which makes using the cross spacers a right pain the backside.
. Any tips there? we're aiming for a 2mm grout joint. Are you supposed to push the spacer all the way in?
Watched a %^$ ton of YouTube videos and read advice, never quite as easy once you get that trowel in your hand!!
Any advice is much appreciated and will no doubt save me some cash (more adhesive and tiles!).
Thanks all and have a good weekend.
