A while ago I read a story about how a spark started off on their career path. As a 7 year old, she decided to test by experiment a thought that I'm sure we all had when we were young: does string conduct electricity? The experiment consisted of a couple of chairs, with the sample piece secured between them. Attached to one end of the string was a metal prong, which was inserted into a 13A socket. The experiment had a couple of huge mistakes that rendered the test inconclusive: firstly the makeshift busbar in question connected to both the line and neutral of the socket and, of course, secondly there was no return path from the other end of the string. Further frustration was caused by the initial abortive attempt popping the 100A service fuse and rendering further testing impossible. Apart of the obvious thing that one would think upon reading this: "so *does* string conduct electricity?" two other thoughts crossed my mind:
1) How often do 100A service fuses pop?
2) When you telephone the DNO, do they simply turn up and change it or do they shin a 500W flood light at you and give you the DNO inquisition?
